Shower pump
20 Sep 2014
Nottinghamshire
Hi
So, we moved into a new house last year. The previous occupiers told us that they had a pump installed to increase the pressure to the shower. This has always worked fine but been very noisy. Yesterday it appears to have stopped working as the pressure has vanished. It still makes a noise but nothing like it did and there is a smell when it is active.
- does it sound like the pump is knackered?
- I have attached some pictures of the pump, details etc. any advice about a decent pump which may replace this one?
I'd recommend Stuart Turner pumps.
Just noticed the disconnected pipes, has it always been like that?
If so that will break the pump very quickly, if you don't need a twin impeller pump then buy a single.
Hi Jim, thanks for the response
Do you think this pump would be ok? what are the factors i need to be looking for to ensure compatability and an easy switch - regenerative/centrifugal, positive/negative head , are terms I've seen banded abuot but not sure how it applies
https://www.screwfix.com/p/stuart-t...-regenerative-single-shower-pump-2-0bar/58748
It has always been like that (since we moved in anyway), doesn't surprise me that it was not done well, been the story of this house so far...
Thanks!
It's positive head only which means it needs the supply to be higher, as long as you're aware of that it should be fine.
Hmm. First picture shows the original supplier as Wren Bathrooms. In my experience, not a premium supplier.
As above, it looks like you only need a single impeller pump. The noise/failure may be because the unused side has been running dry for a long time.
Stewart Turner best choice, and fit a water softener if you need one in your location.
I guessed that, cannot seem to find much about them as a supplier, appears to have a logo of Salamander on the side too.
That makes sense. This house ...:rolleyes: the guy seemed to think he could do everything, my favourite/worst was a wooden frame to hold up the sheet above a multi fuel stove, when we removed this it had charred and burnt, so close to a chimney fire :mad:
I'll go for Stuart Turner and see how I get on.
Hi
So I fitted the pump this morning and all went ok. However, now it is back on the pump is 'pulsing' when the shower is on and only running intermittently.
Anyone got any ideas?
What pump did you install, was it a single ended pump?
You may have a restriction in the pipework.shower, take the head off the shower and try running and see if it pulses. There may also be residual air in the system, run the shower cold then hot then cold again for a few minute, without the pump powered on.
Thanks for the quick response. It was air in the system.
I had turned the shower on (before switching the pump on) to pull water through and clear it, but had not turned the cold water supply back on, so guessing that put air back in the system?
I turned it on, pulled more water through and it appears to have fixed the problem. Thanks for your help.
The only issue I had with the install was in removing the flexi hoses which were there already and replacing with the new. I did this on the outlet pipe, but not on the inlet. I didn't as the hot water was still coming through from the tank and I couldn't work out how to turn this off (other than the isolating thing on the flexi pipe). I do want to switch this over to the proper one, where am I likely to find something to turn off the hot water supply? Or would it be more likely to be something on the tank in the loft?
Yes, that could have allowed a bit of air to be drawn in, once it gets into the impeller then the pump can pulse until it's cleared.
If you look at your hot water cylinder and trace the cold supply pipe running from the bottom of it that will run up to the cold water cistern there should be a gate valve (red handle or another type of valve) that once turned off will stop the cold flow to the cylinder and subsequently through the hot water pipework. Just remember to run the system without the pump powered for a few minutes to, again, expel any trapped air.
Thanks, really appreciate the help.
So, I went up in the attic and found that there is a valve directly off the cold water tank. Its a red circular handle that I assume turns. I took a picture but it would not upload. Is it likely that this would be ok to turn off, swap the flexi pipe and turn back on?
If it's on the pipe that runs to the HW cylinder then yes. Test it out. Turn the valve off, turn a hot water tap on or the outlet of the pump and if it's nice and dry then that's you.
