NEW WIRE - BOILER N to HEATLINK N
NEW WIRE - BOILER L to HEATLINK L
NEW WIRE - 24V RT to HEATLINK 2
NEW WIRE - 24V RT to HEATLINK 3
Yes
It means that the Heat link requires a mains voltage supply to power it (230V) and that the boiler generates 24v for it's control. As the switch connected to terminals 2 & 3 is voltage free it will switch 24v quite happily. Remember the diagram I posted.Does it matter that above HEATLINK 2 & 3 it says 100-240V? And the BOILER RT says 24V...
Notice it is called "LOW VOLTAGE" at the top. The 24v for boiler control is what it is referring to. But the N & L terminals still need to be connected to 230v, because that's what the heat link needs to provide it with operating power.
This is why it is important that the two voltages are kept separate and why I told you under no circumstances should you link terminals L and 2.
