Return Water Temperature Limit valve
10 Dec 2007
Hello.
I have a small (12m2) area of floor to heat and rather than installing a pump/manifold was looking at using a Return Water Temperature Limit valve.
However im not sure if this is a good idea as I cant regulate the flow temp as the pipe enters the floor. I understand it should be somewhere around 45 degrees but it would be nearer 80 as it entered the floor if I just use a Return Water Temperature Limit valve and thus damage the flooring / slab?
Should also use a TMV on the flow or will this confuse everything.
lol. The CH flow will enter the floor (UFH Pipe) at boiler temp of 80 degrees. I understand that a manifold would normally mix this water with cooler return water using a thermostat. Using a Return Water Temperature Limit valve on the return doesn't prevent the really hot water entering the floor.
Am I missing something?
Depending on surface the under floor heating is often limited to 28°C, which is also why it normally is back ground heating only, still needs radiators in the room. So the method used with wet systems is to re-circulate the water around the floor, adding just enough hot water from boiler to maintain the circulating water at 28°C.
Without a second pump the water will not circulate, the only way I have seen to get away without second pump is to feed it into a radiator first, so water is cooled by radiator and the lock shield valve controls flow so it can cool the water to 28°C, this is rather hit and miss, and only see in done in a bathroom where the radiator/towel rail was heated with the DHW not central heating, and to be frank it did not work that well as towel rail was really too cool, and I suspect if the building inspector had realised, he would have insisted it was removed. It was more to cool the Rayburn stove than to heat bathroom.
Yes- a fundamental understanding of how to install underfloor heating!
Well yeh... completely. Hence the question posted on... wait for it... a DIY forum!
I appreciate its not the 100% correct way to do it, a professional may consider a bodge, but also as Gasguru states Danfoss etc sell these so called Return Water Temperature Limit valves. Im unsure its a good idea considering the temp of the flow to the floor.
As the consensus seems to be avoid, I will go for a single zone manifold and pump with blending valve.
