Unvented cylinder with nested coils
Solid fuel heat sources cannot be quickly switched off like a gas or electric boiler can be
I find when I shut the air off, it stops boiling in about 5 minutes.
With pump failure that would be a bit longer.
But then the heat leak rad will kick in.
This is an electrically heated unvented cylinder where the safety devices were disabled.
The power from the exploding cylinder is as you will see enormous.
VIDEO
I think if an unvented cylinder was threw on a fire full of water with an expansion valve fitted it would just jet out steam and water and not explode.
Think I seen a huge gas tank with a fire lit below and most of the gas vented off before it exploded.
Ive seen guys cut gas tanks in half with an angle grinder with gas still inside.
Ha ha I get it , was wondering what name you would use this time Adam, total knob end get on to the commerciall **** and tell them bow great you are , you are well sussed
Eh?
Ryler. you are assuming that safety devices will always work.
I have seen too many incidents where a safety device failed to operate. ( seeing one incident is enough )
It should not be boiling in a sealed / unvented system
What will happen if you are not there to shut the air off. ? Can you safely drop the fire out of the stove or do you have to rely on the lack of air to extinguish the fire ( including mouldering embers )
If you want to connect your unvented cylinder to a solid fuel appliance, you need to do it via a H2 panel. A Ravi stat is not sufficient. It also needs to be installed by someone who is trained and qualified, if you care about your house insurance. Alternatively you can fit a thermal store, which will provide you with mains pressure hot water and can be fitted directly to a solid fuel appliance, provided the coils are correctly specified
The H2 panel is an overly complicated electrical device. And very expensive.
And ultimately prone to failure.
If an electrician is employed to do the install, costs will rise to about £2k.
Thats £2k versus a £150 Danfoss valve.
And the H2 is designed to link two boilers.
Mine are separate.
An RAV1 shuts off the flow with out auxillary energy being involved.
If I disabled the RAV1 on my vented cylinder and disabled the pump, I'd struggle to over heat the cylinder unless I was standing at the stove shovelling coal.
As the heat leak rad (which is about 3kw) kicks in.
Well you've clearly already made your mind up, which begs the question of why you bothered to post on here at all? Crack on, we'll just pipe down and listen for the bang
Not for solid fuel appliances, no, because it's not an approved or safe installation
