Not sure if 'Electrics UK' is the appropriate forum to post as its a question about battery powered LED lights so if I've posted in the wrong section can it be moved to the correct one please....
I'm after some advice about letter lights I've purchased and the best way to wire them all together to work from one switch.
If you look at the photos you will see the letter 'S' I have purchased along with 3 others so have 4 in total with each one having to be powered by batteries individually.
They all use the same power which is 2 x AA batterys obvioulsly 1.5volts for each giving me a total of 4 letters at 12volts.
As I said they are powered individually and I want to be able to turn them all on and off with one switch with one power supply so I would appreciate any info on the best way to do this, I do need the power supply to be quite compact.
Many thanks
Edit - Could it be as simple as extending the on/off switch wires from all 4 letters to connect to just one switch keeping the AA batteries in each letter?
Many thanks
