Husky Beer Fridge not cooking
12 Dec 2009
Cheshire
Hello all
I’ve got an old (ish) Husky Beer Fridge that isn’t cooking as it should , there isn’t any temperature control in the. Cabinet , so I’d hazard a guess & say there was a Thermostat somewhere that’s not working , will it be an easy fix ?? It sounds like the Compressor is running fine
so is it worth fixing
whoops is not cooling NOT Cooking !!!!
cheers
Phil
Hi , it’s in a Cupboard under the Stairs , so it’s my lock down job for tomorrow get it out and give it a once over , I can see the sensor which is on the Cooler plate
thanks for responding , I’ll let you know how I get on
cheers
Phil
If compressor running it is not the thermostat. I used a standard fridge for my beer, and used an external thermostat set to 19.5°C, plus a heater if it drops below 19°C I find on starting the brew motor runs a fair bit first day, then hardly runs, fridge for drinking beer/wine should be set to 12°C however I prefer it cooler at 4°C, standard fridge setting. For the beer to drink I use a freezer with an external thermostat.
When I started you could not get ready made thermostats so used STC-1000 (heating and cooling) and MH1210A (heating or cooling) but today the InkBird 308 is available ready made.
I have a similar set up, is there a dial at the back? Reached from behind the cooler.
Hi , yes pulled the Fridge out today , it’s got a control at the back , but that doesn’t seem to be working , bar when you switch it off , then the Compressor stops working
So I had a look on Flee Bay & ordered a new part , it’s only £3-65 from China so I though I’d give that a try & see what happens , easy enough to fit , 2 screws, 3 push on terminals & install the probe into the Compartment. We’ll see what happens
cheers
Phil
Whilst you are waiting for the part to arrive you can try laying it on its side for 24 hours. Apparently it lets the gas/liquid find its way back together.
Not sure if it applies to morden fridges though.
i have a problem with my husky cooler..it will get cold and it starts to frost on the back inside then cuts out..do you think its the thermostat problem?
cheers
Phil
got a link for this?
