Found a link here to site which gives compass reference to my nearest transmitter to align aerial . Can’t find it now any one help ?
Neither site seems to offer what I need .
That’s the one , thanks.I think what you want is the Wolfbane site: http://www.wolfbane.net/cgi-bin/tvd.exe?
Put in your postcode and it gives a list of all the transmitters on the local region. This includes a compass bearing.
If this or any other reply was helpful to you, then please do the decent thing and click the T-H-A-N-K-S button. (That's the THANKS button, not the Like button, there's a difference) It appears when you hover the mouse pointer near the Quote Multi-quote buttons. It costs you nothing. This is the proper way to show your thanks for the time and help someone gave you.
amazing the things you learn from forums like this. thanksI seem to remember there was a program which you just entered the Maidenhead locator code into, however although all around the world they use the Maidenhead locator it seems to be rarely used in the UK where it was invented. It seems we use Post codes and military map references designed to aim guns so missiles (referred to as ordnance) hit target first time. Seems years ago some one surveyed the UK and made a map to assist gunners, called the ordnance survey map, one does wonder why?
Phone compass , unaffected by anything .
I was going to add, watch out for the local magnetic variation, which is 7 degrees here, but (serious tech question) how come a phone compass is not affected?
Ever tried several phones side by side?I seem to remember there was a program which you just entered the Maidenhead locator code into, however although all around the world they use the Maidenhead locator it seems to be rarely used in the UK where it was invented. It seems we use Post codes and military map references designed to aim guns so missiles (referred to as ordnance) hit target first time. Seems years ago some one surveyed the UK and made a map to assist gunners, called the ordnance survey map, one does wonder why?
That'll be because NGR (ordnance survey) was created many years before Maidenhead... Oh and maidenhead is based entirely on the Ordnance survey database.I seem to remember there was a program which you just entered the Maidenhead locator code into, however although all around the world they use the Maidenhead locator it seems to be rarely used in the UK where it was invented. It seems we use Post codes and military map references designed to aim guns so missiles (referred to as ordnance) hit target first time. Seems years ago some one surveyed the UK and made a map to assist gunners, called the ordnance survey map, one does wonder why?
Since the Irish OS and Mainland OS references don't match, and it only covers UK where as Maidenhead covers the world, that does not ring true.Oh and maidenhead is based entirely on the Ordnance survey database.
Mine certainly is!
