Hi guys , hope everyone is doing well as can be .. Thanks to the help on here I've managed to fix one toilet that was leaking into the bowl..I had left it for months before getting help on here and sorting it out. Only problem was that my water bill doubled from 40 to 80pm because of the leak.. Thankfully the water board monitored my useage for 2 weeks after the repair and it was normal again and the wrote off the excess used. Apparently they allow this and as long as you're not using the mick they will cancel it out of it was due to a leak etc..
Anyway , you fix one toilet and the other plays up . Similar issue slight trickle into the bowl. Looks like the water wasn't stopping and was running into the overflow pipe and into the basin. The issue I have is that this cistern has 2 plastic screws at the bottom. I've drained the water out , lots of black gunk and washers all look like they've had better days. The screws just keep spinning and won't come out! The back of the cistern looks like it's been pva'd to the wall but no screws that I can see. Can anyone help me get this thing off?
Also the dual button is a rectangular shape as is the hole on the lid.. Can you get a flush kit with the same button?
