I've just got a new AEG dishwasher. The instructions say that I should turn the water supply on and off with each use. Simple questions....how many people actually do this? Is it really necessary as the isolation tap is not easy to reach?
It is just yet another example of manufacturers instructions being incorrect.
Isolating would involve heaving the machines out first, to get to the isolators.
Turning the water off and forgetting it can lead to the solenoid valves burning out if the machine is operated.
Then they are installed incorrectly.
Whether you consider it incorrect or not it is the standard method of installation.
Why would you put the isolating valves behind the machine?
Because that is where they are fitted by the builder or plumber in readiness for the machine.
No it absolutely is not, unless you don't know what you are doing. Why would you put the isolating valves behind the machine?
