Some help please.
I have a problem with my boiler firing up with a call for heat from the programmer.
Conventional boiler, potterton Promax HE with a UP2 British Gas programmer.
I noticed if the HW timer was on and not firing up if I scrolled through the Heating setting by pressing the select button through timed once on then off the programmer makes a click noise and the boiler then fires up a couple of seconds later.
So to get my boiler to fire up now for hot water I have set the heating on timed to turn off two minutes after the HW comes on, on timed, so when this happens the click happens heating off happens and the boiler fires up.
If I leave the HW in the 'On' position and not on the timer there is no problem the boiler fires up when the water needs heating up.
