Hotpoint FFU3DK stopped working
If the compressor is not working it won't matter if the fan is working or not, it is supposed to circulate cold air from the freezer section to the fridge.
No, the point is it will not be a DIY job, bite the bullet & pay Hotpoint £150, surely it's worth it on a £400+ fridge freezer.
Yeah thats waht i intend to do when I can get the day off
Might be the only option. I think there is a test mode,a quick Google may find it.
Ultimately the only option may be to bite the bullet
Back again!
I myself ended up biting the bullet and getting a 'specialist' out to diagnose my problem.
They told me it was the defrost stat, but that came as part of the evaporator/heater assembly, which I would need to buy. In addition due to the excessive ice build up in the polystyrene air ducts and fan assembly, that would also need replacing.
I agreed to this thinking it would solve the problem - costing around £240! But I thought at least we'll have it working again!
Within a couple of weeks of the parts being fitted it was showing signs of the original issues (clear solid ice 'flowing' out of the air ducts in the freezer compartment.
I called the company back, they tested everything and said all was OK - they tried to blame freezer being full and other things!
I ended up claiming through CC company and did get reimbursed the cost of the repairs - the problem was still there!
The strange thing is, the defrost heater is working as I get water accumulation around the compressor tray.
It appears to me as if the heater and the compressor are running at the same time? The ice is melted by the defrost heater, but the running compressor immediately freezes the water (hence it being clear?)
I've lived with it for a while, but it looks as though its getting to the point where the circulation fan will start sticking stopping the airflow, i can hear it catching when running occasionally!
Did anyone with similar issues get a definitive reason for the issues and a working solution?
MIB
my hotpoint ffu3dk i have to defrost weekly cos the fridge gets warm how to fix this issue please
