Ok maybe left this a bit late but here goes.
I have a thermal(heat) store in our CH system which supplies mains DHW. Ive noticed as of late the Hot water pressure/flow quite low normally descaling the input from the DHWC primary coil (a gauze filter on the mixer valve) fixes the issue.
However it seems as of late pressure still low which leads me to think the coil is getting blocked, water in this area is hard. Can the mixer valves fail and cause this issue or do you believe it's the domestic hot water coil?
I also have an issue with a few rads never getting warmer than about 35degs some are piping hot.
My thoughts were to hire one of these to flush the DHWC in the heat store and then switch it to flushing the CH system. Yes i would pay someone 500+ to do it proffessionally if i had the money but im out of work and poor. And i do have reasonable plumbing knowledge and ability.
https://www.hss.com/hire/p/central-heating-flusher
Any thoughts very much appreciated.
