New house - central heating not working :(
3 Dec 2004
Hi all.
Before I call out the landlord I wondered if I might have missed anything.
Three year old new build - been here a few months. Turned central heating on for first time today but radiators all cold. Hot water is fine.
Anything else I might have missed? Cheers!
Hmmm I’m still having bother. Have an upstairs and downstairs thermostat. Both on full. Upstairs ok but downstairs radiators still cold :( Any ideas?
Or pump stuck (can you hear it whirring & maybe water/air noises in the pipes). Have downstairs rads been bled?
Photo of said thermostat on full? Photo of motorised valve?
E966EEBF-8976-47AA-8335-D09B3F072755.jpeg B37776B7-56BF-4A0C-84AF-8DC472644098.jpeg
I think it may be the thermostat? When I turn the upstairs one the boiler kicks in but if I turn that off and then turn the downstairs one up the boiler does nothing :(
Quite likely the motorised valve- if you've got a friend get them to set downstairs stat to call for heat while you're at the valve- it should whirr a bit & the manual lever should hardly resist at all when you move it.
EDIT If it doesn't whirr & lever resists movement then you can open the valve manually (push lever across all the way then push it up so as the spring returns the lever catches in that notch.). That should give you heat on the ground floor (while upstairs is calling for heat) and if you're lucky will free off the valve
View attachment 205982 View attachment 205983
Is that a clicky (mechanical) stat, or an electronic one needing batteries?
If a mechanical one, is it clicking as you move it end to end?
If it clicks, that usually suggests valve failure or stuck. If battery, try new battery and resync.
It’s a mechanical one, t6360b. I’ve had some of these fail from new.
@simondyntDBeK do you have a multimeter or two pole voltage tester?
Looking at the pic of the stat it looks oldschool clicky type and I'm wondering if the knob is connected to the innards- it shouldn't really go that far over :)
Plumber just been round - here's your answer folks.
It's a combi boiler with a two zone heating system so hot water is always available apparently and the control below is just badly labelled. The left hand side is actually the upstairs radiators and the right hand side (labelled hot water) is actually the downstairs radiators.
FFS.
Now labelled correctly! Thanks everyone for your input.
Sorry, I should have seen that it was a combi from one of your photos, just overlooked I expect. :unsure: Glad you’re sorted anyway.
