Visonic PG2 PowerMaster GT64 Powerlink 3 ip module
14 Jun 2020
Hi
looking for help with this system. I recently installed the above alarm and broadband module. At first I could see the module in diagnostics menu and ip address etc and then reset my alarm (don't ask) then the module stopped working I assume as I could not see it in diagnostics to check the broadband was there. So the company sent out a replacement module but it too seems not to be working. Tried different cables to the router - no lights to indicate traffic on the router, cant see it in diagnostics no avail. Though looking at the manual it says something like" if you don't see broadband listed, make sure the IP module is registered to the system"
How do I do that?
Without looking t the engineers manual I will take a stab in the dark.
1. you either damaged something during your reset (what did you reset codes or entire panel)
2. its not programmed up properly
3. you haven't reconnected the unit correctly.
Hi secureiam
I reset the panel using the DEF pins to give me master Access as I could not remember my code at time of installation
The alarm works as it should with no errors etc
It's connected correctly as it connects via small ribbon cable and it connects only one way - I have built many PC's in the past so I know it's all connected correctly.
Thanks for getting back to me
Ccarr32051
In that case it should only have been a code default and not affected the programming.
So can the router see the panel?
Without looking at the manual, alarm panels tend to store the IP address, is that the same as on the router, if indeed the router can see the panel.
Hi
No the router does not see the panel and there are no activity lights on the routers port where the cable is plugged in. The module is not listed in the "diagnostics" menu to test it
the manual states "if the broadband module is not registered to the Powermaster, the menu BROADBAND MODULE will not be displayed" though it does not say how to register the broadband module.
ccarr32051
Well in that case I would down power the panel mains, battery, Remove the unit replug it in, add battery turn on the mains power and check module programming.
after that it’s phoning tech support
Hi Secureiam
Thanks I will give it ago. Though as working 12 hr shifts it will be a few days to try this. I will let you know how i get on
ccarr32051
Hi Secureiam
ccarr32051
Hi
I powered down the alarm panel by removing both the battery and mains power waited a few minutes and connected the powerlink module 1st then battery 2nd and mains last. Repeated the procedure with mains 2nd and battery last and still no joy with the panel seeing the powerlink module. I am at a loss??? so either the panel port, ribbon cable or the 2nd module is faulty. Ill think I will send it back and do without the app.
ccarr32051
