Douche
5 Nov 2009
Liverpool
Hi I have fitted a thermostatic douche for a customer.
Every time is used it takes 90 seconds for water to come out unless the temp is set on cold water
I have tried another douche and does the same
The system is a y plan system and all other taps are perfect
The indirect cylinder has an air separator fitted.
Any ideas
Go to manual.
Hmmmm ... unless they are fitted to comply with the regs then they shouldn't be fitted at all and if you are a professional then you shouldn't be entertaining it IMO.
If you are using mains cold and gravity hot then unlikely it'll ever work properly.
