Good evening everyone,
We are in the process of buying a property and I'm a bit stuck with understanding something that has come out of the process. I'm pretty sure it'll be resolved by the solicitor but just interested in others opinions on the matter, particularly with some of the very helpful input I've had from here in the past!
Some time ago, the double garage was converted into an annexe with a bedroom above and both garages becoming a self contained unit. The sellers have converted one half back into a garage and the other half into a utility room, with the bedroom remaining upstairs.
In the half which is going back to a garage, all the plasterboard has been removed from the walls (ceiling remains) and a new wall built to provide the 'external' wall to the utility - all fine so far.
We knew that there was a building control application open for this work and the sellers said that it would be completed. Again, all fine. Our solicitor asked for the certificate and one has been provided that was signed off at the end of last month.
We had a survey completed early last week and one of the things highlighted was in the garage, the edges of the ceiling were open from where the plasterboard was removed from the walls and would be a fire separation hazard (I'm not sure if separation between a garage and bedroom should be 30/60/90minute protection? Not that it makes any difference with such big gaps).
So the question is; how can a BC certificate be signed off as work being completed with such a glaring (is it?) defect that is then picked up by a surveyor a mere 6 days later?
Thanks in advance.
Thanks in advance.
