1st post on the forum, found via google and I see the topic of accumulators has been asked a number of times prior, I'm hoping for some advice based on our situation! I've probably gone too far with the detail, so apologies for the long read!
We live in a small village where the mains water flow/pressure isn't great. We have an unvented hot water cylinder (megaflo) linked to a system boiler, therefore our hot and cold water performance is based on the mains pressure. We only have 1 bathroom currently but are planning a loft conversion to add a second bathroom (shower). We've just renovated our existing bathroom and have a Aqualisa digital shower, its nice but the flow isn't excellent (passable but not great, see below).
I'm considering 2 options currently:
- a pumped accumulators like the Accuboost (450L version) https://www.salamanderpumps.co.uk/product/accuboost-450l-pumped/59
- a breaker tank and pump like the DAB sybox / sytank https://www.anglianpumping.com/product/mains-pressure-boosting-systems/dab-e-sytank-and-e-sybox-pump
This would live in our garage, which is attached to the house and has a spare bedroom above (there is noise from the boiler / underfloor heating manifold already but we wouldn't want something super loud.
Measuring our cold water flow today I have the following readings (the kitchen sink is a mixer type tap, the bath has a standard dial for hot, dial for cold).
Outside tap on its own 14.8 l/min
Outside tap + 1 other outlet open 12.5 l/min
Outside tap + 2 other outlets open 11.11 l/min
Outside tap + 3 other outlets open 10.54 l/min
Bath cold tap on its own 9.92 l/min
Bath cold tap + 1 other outlet open 7.56 l/min
Bath cold tap + 2 other outlets open 6.06 l/min
Kitchen sink cold tap on its own 8.13 /min
Kitchen sink cold tap + 1 other outlet open 6.16 l/min
Kitchen sink cold tap + 2 other outlets open 5.3 l/min
Shower set at 40degrees on 'max flow' (which should be 12l/min) = 9.16 l/min (no other outlets open).
I've ordered a water pressure gauge to test the pressure of outside tap (that's the only tap with an accessible threaded connection) which I'll do on the weekend, not expecting it to be much above 1bar though!
Based on the above, which way should I go? I know the sytank would give me 500L of usable water vs half that in the accumulator, but I worry about the increased legionella risk, and not sure we need 500L really!
Both options are within a few hundred pounds of each other.. Would the pumped accumulator be viable? What are the cons of the sybox/sytank set up?
