Looking to floor the bottom floor of my house in engineered wood. I am thoroughly, thoroughly confused on how to do this. I’ve just read 4 articles which contradict each other entirely!
the job:
- 1939 terrace. Lare crawl space below which is dry as a bone.
- floorboards are in good condition, some high and low spots but boards aren’t noticeably damaged or cupped.
- i have a hallway (approx 5m2) which joins into the dining room and living room. I plan to threshold separate this under the doors.
- the dining room and living room are one big room with a connecting double doorway (I removed the interior doors)
- the run from the dining room through to the living room is about 7.6M. I would prefer to not break the floor under the (now removed) double doorway.
- the width of both rooms is about 3.3m.
- the long run (7.6m) is roughly east to west so the sun is running that way.
- I want the boards to run the same way (ie along the long run rather than side to side along the 3.3m)
- the existing floorboards run this direction too.
I initially considered buying 20mm engineered and going straight onto the floorboards but felt this was asking for trouble as the floor will be running the same way as the floorboards. Also I just feel straight onto the floorboards isn’t a good idea. Also 20mm is darn expensive.
So I then decided to lay 6mm exterior ply over the floorboards and probably a 14mm engineered wood T+G.
now this is where it gets tricky. Some articles say that 7.6m run is a bad idea for nailed/glued and floating is better. Others say you need loads of threshold expansion gaps for floating (so the 7.6m run would need a break under the old door space)
so I then thought ply subfloor and nailing the engineered wood.
I then saw articles claiming you never nail unless it’s 20mm hardwood.
most are saying glueing is mainly for concrete subfloor
I don’t care either way, I’ve done a floating floor before but happy to buy a nail gun. I just want a floor which won’t be buckling etc for years to come.
so come on, what do I need to be doing here?!
Thanks in advance for your help!
the job:
