Floorboard screw recommendation
29 Jan 2009
Essex
Hello all,
About to install some 19x145mm soft wood floorboards square edge. Rather than nail I would prefer to screw, I see there are some small head screws, some with twin threads etc.....just wondering if anyone has any recommendations?
I wasn't sure about the twin thread, they do pull the board tight?.....need 50mm wouldn't I for 19mm boards?
They do other sizes, twin thread stops it working loose over time. Could use T STAR if your worried about tightening.
Always used 1&1/2x8 screws. With modern screws any screw that has threads close to the top will cause 'Ramp-up' unless every board is clamped down every joist before every screw is put in. Eventually you will have creaks and most probably an un-level floor.
For small head screws I'd suggest these
https://www.toolstation.com/spax-wirox-t-star-plus-solid-wood-flooring-screw/p19502
Do you think I'd need the 45 or 55 for 19mm square edge pine contractor flooring? I always thought it was the 1/3 rule, so it would be the 55, but not 100% sure as never used these fixings before.
Also reading the description of these screws are they actually meant for the type of flooring I'm using, its written in such a way it could be both solid wood & t&G or maybe they mean solid wood T&G....
yes normally 1x1+50% [2.5 times]so 19+19+9mm so 45 or 50mm [47mm]
but that includes perhaps 20% give or take with no problem as belt and braces :D
so 35-40mm would probably give you sterling service without a problem but at that level problems are far more likely to happen so your choice really ??
These guys are only available in 45 or 55mm so thats my choice, with a T10 drive, old hard as hell joists may be asking for trouble with a 55mm length @3.5mm dia so should try the 45mm I think.
