Gutter Press gushes forth at
Status
Not open for further replies.
As the author explained, they see the bias towards white people, by BAME as racial prejudice. They are not denying the existence of such racial prejudice, they are openly acknowledging its existence.
But it can't be racism because the BAME people are not in a position to establish a BAME superior society that structurally disadvantages white people.
So the author draws a distinction between 'racism' and 'racial prejudice'.
That there is my point,
There isn't a distinction between racism and racial prejudice, they are the same.
You can't just start redefine words willy nilly to support ones narrative.
If a black person hates whites and makes it known as such and beats up or makes remarks against whites in a negative way that is racism. That is them being racist.
It would be the same for a white person against a black person.
Either way the confrontation is racially motivated.
The author has a perfect right to interpret racism and racial prejudice, if they so desire. They explain in detail why and how they have separated the two.
They are not denying the existence, not the seriousness of either. They are simply trying to separate the two terms.
The author describes that as racial prejudice because the black person, and the social hierarchy within which they exist, does not allow them to discriminate unequally on a societal level.
No. A white person is subject to unconscious bias, is in a position to benefit from structural inequality and can discriminate from that position of structural inequality. For example the structural inequality of the MET and other institutions. It is difficult to describe the culture as racial prejudice. That might be the premise on which it is based and perpetuated, but the culture is racist, and incorporates unconscious and structural bias, some of which the participants might be unaware.
The author, and I do not disagree with that.
The author merely terms the one racial prejudice, and the other as racism. Therefore the one has only immediate reasons, motivations and repercussions. the other stems from a long standing premise and have repercussions that serve to underpin that longstanding premise.
I've just switched the news and commentators off at present.
For a couple who didn't want publicity they certainly are hiding themselves away...
Caught 5 mins of news last night.
Member of public asked for comment said “why don’t the public just leave them alone”!!!
Unbelievable.
Then when it happens, what do you suggest it is called, because you appear to object to it being called racism unless you have approved its use?
What you appear to be saying is "it's not racism unless you accept it as such".
Do you not think others have as much right to judge sentiments as you?
You are suggesting that racism is non-existent or of little consequence. Don't you think the victims of racism are in a better position than you to judge the seriousness of it.
Do you make the same argument for rape?
How does your argument look when used in a different scenario, "you allow people to weaponise marginal or non existent rape and that diminishes the seriousness of genuine rape."
Have you ever made that argument? If not why not?
How about "you allow people to weaponise marginal or non existent theft and that diminishes the seriousness of genuine theft".
Why do you only make that argument for racism?
So what you have done is taken my points to the extreme end of their possible interpretation to try and make them less valid and have accused me of suggesting that racism is non-existent in another attempt to shut down the discussion.
I am not saying that its only racism if i have approved its use. I am not saying that its not racism unless i accept it as such. I am not suggesting that racism is of little consequence. I do think that other people have just as much right judge sentiments as me and that is exactly the point. I should be able to say that i don't agree with an accusation of racism without an automatic accusation of being racist.
For example, i do not thinking asking your entire workforce to wear black face masks (where the corporate workwear is also black) is racist and i should be allowed to state that i don't think its a valid accusation without being accused of being institutionally racist.
About 20 years ago i was in a position where i had to make redundancies. I made 4 people redundant, one of whom happened to be black. He accused me of making him redundant because he was black. I was suspended whilst the company (a multi national manufacturer) investigated.
I had selected him through a matrix and he had a poor absence history, shorter service and was less skilled than the person he was compared with who happened to be white. I coincidently had a 50:50 record of employing people from white/non-white backgrounds which reflected the make up of the population in that area of west london. The accusation was therefore dismissed, i was reinstated and the redundancy upheld.
The accusation of racism was unfounded and malicious. The individual concerned knew the real reason for his redundancy, but openly told me he was going to 'take me down'. If it happened now, i suspect that the redundancy might have been overturned because of company's fears of bad press associated with accusations of racism.
That would not be right or fair.
The automatic assumption that every accusation of racism is valid should not be the default. Every accusation should be considered and if found valid should be dealt with robustly, but there should also be the right to challenge whether it is actually racism without being hauled over the coals as a racist.
With regard to your analogy about rape, if you allow people to weaponise non-existent rape then it absolutely diminishes the seriousness of genuine rape. People that cry wolf about rape or maliciously accuse other of rape absolutely make it that much harder for those who genuinely have suffered rape.
Can you not tell the difference for what is racist and what is not?
Clear racism in the video. We don't know if the racists were
Black.
White English
Other English
Eastern European.
But it was clear.
You and others have problem in that if someone even says the word Black then it's racist.
You are even dumber than I thought.
I went up to a woman with a hijab in Sainsburys and said look at that **** not wearing a mask.
It would be funny if you got the terms correct. Even bad at jokes. There are few clogged toilets that need plunging. Go get your plunger and wade in. :ROFLMAO:
G, adding very valuable advice as always, Nice. Haven’t you got a bridge to hide under?
It was you that took the extreme view, and suggested that prejudice should not be described as racism until, you or some formal process had determined as racism.
So you do want to examine every allegation to determine if you think it is racist, otherwise it must automatically not be considered racist and the victim is weaponising the term. You originally said, "At the moment, the woke brigade are pushing the 'if a black person thinks it's racist then it's racist'. But for me it isn't that cut and dried."
This sounds like a nonsensical scenario. The corporate workwear is black, and there's been no complaints, yet you expect us to believe that suddenly there is an objection against wearing black masks.
On that basis you want to examine every allegation of racism to see if it's justified?
Like rape? I can make an allegation of rape, and if the rapist disagrees with the allegation they have a right to defend themselves against the allegation.
But you want to prevent the allegation of racism before it can be examined.
Imagine the scenario:
Officer, I want to report that I've been raped.
Sorry, miss, you can't make that allegation until it's been judged to be rape, and I think you're weaponising the allegation.
Can you see how nonsensical your comment is? You want to deny all allegations of racism until each incident has been judged to be racist.
That is why such allegations are investigated. But with racism, you want to decry all allegations until they have been determined as racism.
See my scenario above.
Similarly:
To whoever it concerns, I want to make a complaint about being abused
Sorry, Sir, you can't make that complaint until it's been determined to be abuse, and I believe you're weaponising the allegation because you're woke.
And you have only thought of this when racism is involved. It never occurred to you about rape, theft, etc.
Status
