Hi All, new here. Just connected up a 3rd Gen Nest Themostat to my vaillant 828 Turbomax Combi.
When I turned the boiler powered back on after connecting up the heat link I Set the temp on the thermostat (via app) to 30 degrees so a call for heat would be made.
Heard a click on the heatlink and the boiler fired up and rads starting warming up.
So I flicked the temp down again below the current room temperature (again via app) and the boiler stopped heating .
This indicated everything was working as expected.
However when I tried it again, the heat link clicked but the boiler never fired.
So I disconnected power to the boiler, checked all wiring (all seemed ok). So I restored power and did the same test again
Again, the boiler fired up., and then tured of when I turned the temp to below room temp.
But on second attempt heatlink clicked again, but boiler did not fire.
My previous thermostat was a honeywell which I disconnected and working without issues.
On the Boiler I have set the clock / time to the sun symbol now that I have installed the nest.
The heatlink always 'click's so the message is being received but nothing happens tat he boiler unless its the first time after i turn on the power to the boiler.
So it seems that the boiler only seems to fire up when asked to do so the first time after power is restored to it (seems odd?). Does anyone have any ideas on what could be causing this?
Thank you
Thank you
