I'm about to fit the the floor in the ensuite but before I do I just wanted to check what the best advice is for fitting a stone resin tray?
It is a low profile 800*1000 offset quadrant.
Option 1 - just lay the chipboard floor and then seal the floor with some tanking stuff. Then use a bed of sand and cement on top to bed the tray.
Option 2 - lay ply where the shower is going instead. If this was the case it would probably be easiest for fitting to just use an 8x4 sheet for that end of the bathroom. Then use chipboard for the remainder (would just lack a tongue at the join but I could add noggins there to support)
Option 3 - lay the chipboard floor, then lay some 9mm ply on top. Cut to the shape of the tray.
