I have no idea please tell me ?why do you think I said in #4 "at pressure 2 barg = 3 bara"?
Because it was relevant to the estimate I made. It shows I do know the difference between gauge (barg) and absolute pressure (bara).I have no idea please tell me ?
well start with sorting thatIt's a rough guess based on the dial that's on the boiler, essentially shorthand for it's dropping a 'little bit' each day.
We have an external draincock that has a weep on one of the joins, the original question was to determine if that could be the reason for a small but noticeable daily loss of pressure.
without knowing barometric pressure, system volume and system temperature at each measurement I wouldnt have a clue, was the pump running at first measurement and at second measurement,is it a fixed rate pump ? is it an ERP pump, what was demanded on the system was HW and all zones open when taken, the answer is I havent a clue and neither do youBecause it was relevant to the estimate I made. It shows I do know the difference between gauge (barg) and absolute pressure (bara).
BTW what would your estimate of volume for 0.1 bar pressure drop be?
You could try reading the OP's #18, I think we can give him credit for having the common sense to quote a typical figure over a few days, averaged over temperature variations. Do you really think variation in barometric pressure would make a significant difference? If the pressure vessel is close to the pump suction, as it should be, that fixes the minimum system pressure, and the pressure at the vessel connection varies very little whether or not the pump is running.without knowing barometric pressure, system volume and system temperature at each measurement I wouldnt have a clue, was the pump running at first measurement and at second measurement,is it a fixed rate pump ? is it an ERP pump, what was demanded on the system was HW and all zones open when taken, the answer is I havent a clue and neither do you
What does the vessel have to do with it ? please explain why some boiler models need to see a pressure differential once the pump has been powered before they will allow the boiler to fire , if a boiler expansion vessel is correctly charged and the communication is clear then it will never affect anything to do with the system pressure, the primary water temp will, as will the pumpand the pressure at the vessel connection varies very little whether or not the pump is running.
Any developments on this?It's a rough guess based on the dial that's on the boiler, essentially shorthand for it's dropping a 'little bit' each day.
Did you do the Gorners test a la #21?No not yet, the company that installed the boiler were supposed to be coming on Friday to fix the draincock... but that didn't happen![]()
