Hi all,
I'm currently in the process of building an outside office in the garden. Due to the distance from the consumer unit I'll be spurring off a socket inside the house with 6mm SWA. I chose 6mm just in case we decide to go to the consumer unit in the future.
Because it's only a spur and not a new circuit I'd like to do as much of it myself as possible, I've made a diagram below which I believe works well. The sockets are straight forward, the SWA will be terminated in a 13A FCU and then into the first socket continuing as a radial, all in 2.5mm T&E.
The lighting will be a case of taking the 2.5mm from the 13A FCU in to a 3A FCU and out of that will be 1.5mm T&E to the light switch (it's only a small room so doesn't need 2 switches). From the switch to the first downlight and then daisy chained (radial) from there.
The additional wires in the diagram are just for speaker wires, HDMI and Cat6. The Cat6 will be protected as much as possible from the power cables. All wires will be run behind the celotex insulation in the walls.
Is there anything I've done incorrectly or anything that could be done better?
Diagram below with a more detailed diagram of the lighting circuit.
