- Joined
- 27 Jan 2008
- Messages
- 28,793
- Reaction score
- 3,515
- Location
- Country
First e-bike came from Halfords who did all the settings so my wife could simply ride it, nice mid motor step through frame with hydraulic disc brakes, 7 speed derailier gears, but slightly on the heavy side, no longer on sale think around 22 kg.
Seem to remember bike rack rated at 40 kg, it was selected as it allowed us to carry bikes and tow a caravan, there was a plate that fitted behind the tow ball.
Also hard to secure the bike when on a bike rack and can only carry with the one car, so seemed a good idea to go for a folding e-bike for me, a little heavier at 25 kg, but can carry in the boot, so when a second hand one was advertised it seemed a good idea, so got one of these or very like that one, controller not mounted in same place, but it seems it is a standard frame.
However it showed km/h and clearly would prefer MPH, nothing in the manual to show how to change it, however some playing and I found pressing up/down at same time goes into a menu,
and there are 17 settings, the km/h to MPH was clear as number 2, but the rest were just numbers.
An internet hunt found USA sites where they seemed to know what they all are, and it seems similar but not the same as mine, there is no ID number on the display
so can't hunt for identical model. Seems in USA allowed up to 750 watt on the road, maximum speed of 20 MPH but in UK 250 watt and 16 MPH, and it seems mine is set to 350 watt so needs to be set to 250 watt to be legal. Also needs to be set to pedal assist only, at the moment it is both pedal assist and twist grip.
It seems likely below is the way mine is set, hence I say possible as not tested, but some of the values don't seem to make sense, 350 watt at 48 volt is 7.3 amp, but where I think is amps it says 12, if it said 7.3 then dropping to 6.2 would make sense.
Also it says speed limit if sensor fitted, can't see one unless built into motor.
So I am loathed to play in case I damage some thing. So wonder if anyone has already played with the settings and what was the result?
and there are 17 settings, the km/h to MPH was clear as number 2, but the rest were just numbers. An internet hunt found USA sites where they seemed to know what they all are, and it seems similar but not the same as mine, there is no ID number on the display
so can't hunt for identical model. Seems in USA allowed up to 750 watt on the road, maximum speed of 20 MPH but in UK 250 watt and 16 MPH, and it seems mine is set to 350 watt so needs to be set to 250 watt to be legal. Also needs to be set to pedal assist only, at the moment it is both pedal assist and twist grip.It seems likely below is the way mine is set, hence I say possible as not tested, but some of the values don't seem to make sense, 350 watt at 48 volt is 7.3 amp, but where I think is amps it says 12, if it said 7.3 then dropping to 6.2 would make sense.
