C
Captain Nemesis
Too rightone of the recommendation was to insulate the solid concrete floor (the cost of this I'm pretty certain would never be outweighed by the energy efficiency I'm sure)
https://news.sky.com/story/covid-19...-winter-to-decrease-coronavirus-risk-12135381If you want to make a noticeable difference, regardless of EPC; hunt down any cold air draughts!
Grant schemes like last year's Green Homes Grant?The solution is either government grants to upgrade existing housing stock or start to rebuild.........
You can now be fined an unlimited amount and/or be banged up for 2 years for Building Regs contraventions.It's a catch 22. No guarantees whatsoever that a new house will be better.
The "performance gap" is very real and that will not change unless this stuff is explicitly inspected and cared about during any work, including new builds. The lack of care and knowledge is nothing short of shocking accross the industry, especially when doing it correctly in terms of energy use would require no extra time, effort or cost at those build stages. Its very difficult to make doing it properly valuable to the builder on the ground, why on earth would they know that PIR insulation doesn't have a constant resistance value and loses significant performance under 10C? There is no incentive structure.
New build means paying a premium and a heap of snagging issues into the bargain.I don't think any of the options are truly feasible now that we are discussing it.
Personally I don't like new builds because they are rarely freehold these days, and there is usually a grounds charge. We looked at a new build before we moved into our current house, and the ground rent was around £250 per month, plus a shared cost should anything major be required to the roads and paths etc.
Drive one of them into bankrupcy with fines and lock up the directors.the big housebuilders are driven by shareholder profits -so they build to a tight deadline and screw the pants off subbies.
Because the public have been brainwashed by the disgusting gutter press to equate any radical proposals from Labour as dangerous loony left fantasises which will bankrupt the country by teatime the day after the election and to have huge personal animosity to all Labour leaders.I dont understand why we dont have the Labour government all over this -they should be looking to for radical solutions to solve this housing crisis.
Solar panels would probably get you there and pay for themselves within 10-15 years max. Although not if youre paying 5-8k for a 2.5kWp system.These are the recommendation from the surveyor.
It's quite an expense to get the property to a C grade by the sounds of things..
I was a labour supporter before Corbyn, the party went a bit down hill, some policies were just far to radical, and others not radical enough.
The Tories appear to have made the zero carbon commitment without really thinking bit through, and are now trying bumble their way through it with poorly thought out schemes.
Since starmer took over labour...
If you add insulation to the outside of the house it stops the walls warming up so much when its hot outside.Yes you can add insulation but, it's actually counterproductive because they say the country is the getting warmer, by adding insulation you're also risking the property in being hot in the summer months.
