Cold water getting into the secondary return?
30 Jul 2021
Hi there, help please how is it possible for cold water to get into the secondary return flow back to the boiler.
I have a large house and a 300 L tank I have noticed that when I turn the hot tap on that the temperature on the secondary return Pipe to the tank cools rapidly. However if I turn off the cold water supply to the same circuit i.e. the first floor, then the temperature doesn’t drop. I hope this question makes sense?
is it a dedicated secondary return tapping or is the secondary return teed into the cold water inlet ?
I don’t know the answer to that but my question would be in what circumstances would it be teed into the cold water system?
With the exception of a couple of outlets and some taps all the showers and baths have hands grohe I boxes installed.
As the cold water feed inters the cylinder at the bottom.
Has a non return valve been fitted in the secondary return?
some cylinders come with dedicated secondary return tappings , some dont and the cold water feed is used, not the best way to do it but it is common, if doing it that way a non return valve should be used, still not correct but will work, post a pic of your set up
