secondary return hot water
4 Apr 2010
Humberside
When fitting a secondary return to a large domestic property is it usual to tee the return in to the hot a one point? Or more than once? Is it usualy tee'd in at a hot draw off furthest from the hot water cylinder?
Normally as close as you can to each draw off point, and with a lockshield on each return.
How does that work ? if you have a loop from cylinder take off back to say the cold feed (unvented for example) the water is just going in a circle, so what changes concerning the loop when you open a tap ?
Nothin changes.
The idea is that as soon as you open a tap you have hot water.
You need it to go to the furthest point as its never installed as a perfect circle.
the lock shield valves are only used if there are branches or it is not one continuos loop....
pumps too have sensors and shut down if the return reaches a certain temperature...
For casual readers it may help if I point out that there are some different applications being discussed here.
The return from each hot outlet is mostly used in hotels etc.
But most domestic properties only have a single loop for the whole house or for each floor.
Tony
Balancing to avoid short circuiting, you want flow at all points.
There are TRV-type valves available for HWS for this application; they sense the water temperature (not the air temperature as do TRVs) and close down as the water heats up. They're useful for big systems with a variable speed pump.
E.g.,
http://heating.danfoss.co.uk/xxTypex/209446_MNU17431795_SIT313.html[/QUOTE]
Can't think of the ones we've used lately. They aren't danfos but exactly the same thing. You set the temp on the head an there's a little dial to prove your return water temp.
More beneficial to long drops, say in vertical voids. We used them in a hotel refurb.wouldnt fir them for single outlets etc as no point in Te cost.
Have to look under the office desk later as I've got loads left.
