Video doorbell power supply
20 Oct 2010
Lanarkshire
Hi just wondered can I take power from the lighting circuit, I have no power at the door and no way to get it but wondered if I could take power from the light circuit and use that. I was thinking taking a L,N&e from the live @ the light switch up to ceiling level install a switch/breaker of some sort along with a transformer and then drop the cables back down to the doorbell. Yes or no ?
How many wires do you have at the light switch ?
Are there
(1) A Brown and a Blue both to the switch
or are there
(2) Two Browns to the Switch and two Blues to a terminal block.
If (1) then there is no Neutral at the switch, the Blue is the Switched Live
If (2) then most likely the two Blues in the terminal block are Neutral and one of the Browns is Live and the other Brown is Switched Live
Just finished dropping a new 3core and earth from ceiling down to switch so have a live and neutral there
You may or may not have neutral at the switch- depends how the circuit has been wired. You will almost certainly have permanent live and neutral at the light fitting...beaten by @bernardgreen .
Whichever of the 2 scenarios you have, yes you can power your transformer from the lighting circuit. It's a good idea to use an FCU to make the connection to the transformer (make sure it's a double pole switch type, put a 3A fuse in it, mark it so the next person knows it's on the lighting circuit), then bit of 2 core flex to your doorbell and off you go.
Good advice, a failed transformer that trips the RCD and puts the lights out is quickly and easily isolated by a double pole switch thus allowing the RCD to be reset and the lights restored
A FCU is not required on a lighting circuit as a 3 amp fuse has no discrimination against a 6a MCB. Put a switch if you like (you will never use it).
Fair point re the fuse long as the lighting circuit is 6A, it was more the dp isolation can be handy if the PSU/transformer melts.
Thanks to everyone for the helpful replies will follow your advice when I decide to proceed
Double pole switches (without fuses) are available. Never known a bell transformer to fail or melt.
