Fan rotates freely, wind is blowing now.Does the fan rotate freely when off?
It could do with a clean.
No details re wiring on the cover. Between Brown & Grey 230v no voltage on black. This is with light on.There is no white wire. The colours are brown, black and grey.
In your photo you missed out the cover which - I hope - says which terminal is which. Probably they are L, N and T?? Your first job is to test for voltage between N and L. You should get 230v. Then you need to test between N and T, there should be 230v with the light on and )v with the light off.
Please confirm your findings and we can advise further.
How about between black and grey, with thd light on?No details re wiring on the cover. Between Brown & Grey 230v no voltage on black. This is with light on.
Thanks for reply.
0vHow about between black and grey, with thd light on?
I dont mind replacement as long as the cables enter/terminate at the same place.Possible reason - have a look at the electronics - specifically at the capacitors (the two blue coke can shaped items at bottom right of image). If their silver tops are slightly domed then these have failed and either need replacing (if you have a soldering iron) or a whole new fan unit.
Had to replace these on an extractor fan only last week. The hot resistor located right next to the capacitors had damaged them in only 4years.
Just tried that, fan still no going.Try turning the power off at the DB/CU, move the yellow that goes into the black and put it in with the red, turn the power back on, does the fan run? (it should run all the time and not stop), put it all back as it was and report back
That tells me you have a wiring fault, not a fan fault.
Sorry for delay in reply. Yes to what you have said.So just to confirm, when you were testing it, you had both the red and yellow from the fan to the brown comming in, and the black from the fan to the grey comming in. And you had previously got 240v between the brown and the grey?
