uPVC holes
10 Jul 2016
I am getting my uPVC doors sprayed however there are a number of holes on the frame (see image). I need to make good before spraying. Any advice on how to go about this? Some of the plastic is sticking out and needs to be flush (I assume) before filling I tried a stanley knife but that didn’t cut it (literally). Thanks in advance.
Sand it back to flush with an abrasive paper, on a backing block, before filling - pushing the filler well into those holes, then sand again with some finer abrasive. The guy doing the spraying, if a specialist, might do this for you as part of the job.
With warnings like these I'd make sure the door is wide open when using it.
  • Causes serious eye irritation.
  • Causes skin irritation.
  • Highly flammable liquid and vapour.
  • May cause drowsiness or dizziness.
  • Suspected of causing cancer.
  • Suspected of causing genetic defects.
  • Suspected of damaging fertility or the unborn child.
Jesus Christ, or a hazmat suit and gas mask? Crikey, didn’t even notice that. :eek:
