No. Why would I do that?! Plus its not yellow in the inside. Its on the outer parts outside glass doors.Do you wee in the shower? Have you tried cleaning it?
Andy
Yes. I have tried cleaning it with elbow grease and other stuff. Still doesn’t come off. Its like a permanent stain!Aerosols reacting with it ? As @HERTS P&D said, have you tried cleaning it ?
Wrong screw?looks like corrosion, maybe used the wrong screw somewhere.
...the mark at the bottom of the shower door might be a rust stain, from screws used on assembly. BZP will rust if kept damp. If you can get a pure phosphoric acid rust remover (Jenolite liquid used to be, but I believe is discontinued) and tape cotton wool or kitchen roll against the stain, wetted with acid, it will clean it off. But you will also need to remove the rusty screws and replace with stainless.
What do you mean? Your english is poor. Explain it better. I didn’t purchase the items online. I got it from a local shop near me.Could you have bought cheap crap off the Internet and got someone even crapper to fit it?
