Sounds like a plan.I think I might have sussed out another way to make this work using momentary switches. You can set the sonoff at software level to recognise a momentary switch as an 'ON' signal. The following schematic will allow me to connect both switches with the pre-existing twin and earth. I'll just have to replace my standard switches with momentary switches:
If i've understood the design correctly it's not a case of "could jump", it's a case of those terminals being live with a substantial pulsating DC voltage in normal operation.To make sure I've understood correctly... he shouldn't use the unshielded earth because the mains voltage could jump from the live terminal to S1 and S2. Is this correct?
They do, and I've often wondered why, since the switches in question only seem to have a slightly passing relationship with the dictionary definition of the word. Does anyone know how this use of the word came about?BTW manufacturers of electrical accessories use the term "retractive switch" for momentry switches.
He must not use the bare copper CPC in T & E cable for anything other than CPC. If you had 3 core flex you can use the green/yellow core for other purposes in some circumstances if you sleeve it with something not green and yellow.Thanks guys
Going back to my brother-in-law. I'll try to feed this back to him.
Thanks again
Albeit you're referring to something I wrote about 9 months ago, in what sense does that explain how momentary-action switches came to be known as "retractive" (which is what my comment/question was about) ?The expression " switching from daylight to lamp light " may be the origin from days long gone ( gas lights on the street )
What is your objection? I think it far less dubious than other terms we have to endure.They do, and I've often wondered why, since the switches in question only seem to have a slightly passing relationship with the dictionary definition of the word.
A minion at CEF or similar ???Does anyone know how this use of the word came about?
No objection at all. I was just wondering (~9 months ago) whether anyone knew how this word "retractive" came to be used in the context of switches!What is your objection? I think it far less dubious than other terms we have to endure.
That's probably the nearest to a credible 'explanation' I've heard.... The first time I heard "retractive" applied to momentary-action switches was when talking about pull cord switches in the warden call system of a sheltered home community. The cord will "retract" when the person lets go of it.
Oh, sorry. I thought you were implying it was inappropriate.No objection at all.
As I said, not at all - I' was merely curious/intrigued!Oh, sorry. I thought you were implying it was inappropriate.
