- Joined
- 17 May 2012
- Messages
- 11,458
- Reaction score
- 1,048
- Country
I noticed this weekend that water accumulated under items in my shed.
It first, I thought it was just items on the floor, but then same happened with something on a shelf. The shed has a single large air gap and the door is not exactly a tight fit, so air flow should not be a problem. It sits on a concrete base that does not have a damp membrane in it. The base is close to the house soak away, of that is relevant ... but not right next to it.
Could excessive moisture build up underneath be a problem? Should I make some air gaps under the shed, as the base is "closed" and no air gaps (this shed was originally built on sleepers on a lawn so would have had airflow below)
Was wet under punch bag:
And wet under a bucket (bucket did not have a hole!)
