Hi, after much trial and error have managed to balance the heating system to the best of my ability (radiator side at least) upstairs rads are a 1/4 open on the locksheilds even at a quarter turn they still get roasting! and the final radiators are fully open, I have got them all to the point where they all heat up at exactly the same time. However I have a y plan system and the hot water and radiators just do not work well together when both on at the same time, so because of this I feel its better to leave the hot water on timed whenever the radiators are being used, (the hot water on was constant at the programmer because I found the cost to be negligible, but it's costing me where the radiators are concerned because they take far too long to heat whenever the hot water needs topping up).
The balancing valve on the return of the coil is set exactly 1 full turn, the hot water reheating times seems to be adequate enough, after a 5-10 minute shower (power shower) the hot water reheats within half an hour, however as I plan to leave the hot water on timed whenever heating is used I am unsure what to do with this valve? Can I open it fully or half open? It takes 4 and a quarter turns from fully closed to fully open, I feel the heating recovery time could be better, after a bath it takes over an hour to reheat.
The boiler I have is a worcester 18ri and it's set to approx 70 degrees (3/4 on the temperature control) the hot water is set to 60 as you would expect, the system is just a standard gravity pumped open vented system from approximately 1998 when the house was built, everything on the system is original except the boiler.
I understand the boiler will never condense in hot water only so is it better to leave the balancing valve fully open as I no longer plan to use heating and hot water at the same time, the reason I ask is because some say with this valve fully open the water will flow to quickly and coil won't heat properly and it will make the boiler modulate, is there any truth in this?
Also Is my cylinder likely to have a fast recovery coil if it was installed in 1998 approx? I just want the fastest hot water recovery time so would like to know the best setting for this valve?
Hope this makes sense
