Replacing 15mm pipe with 22mm in gravity system
8 Mar 2022
I have a gravity fed hot water system (header tank in roof with hot water cylinder upstairs). The hot water system is plumbed with 22mm as far as the upstairs bathroom, but where it drops down into the kitchen downstairs it uses 15mm pipe.
The hot water flow rate in the kitchen is not particularly good, would there be any gain in re-plumbing with 22mm as far as the kitchen tap tail or would I just be wasting time and money for little gain?
My guess the latter. Mine is plumbed pretty much entirely in 15mm and reasonable flow. Are there any valves which might be stuck part open? Maybe worth trying a different tap.
Yes, I suspect the tap is the root cause but that's the one she likes. Just wondering if replacing the final 15mm section so it's 22mm from cylinder to tap tail would make any appreciable difference.
if your kitchen taps are new and use flexi hoses that will be the problem
