Triton Shower Leak
1 Jul 2019
Hi. Just wondering if anyone can help with some advice regarding my partner's shower, which is leaking/dripping. I'm guessing it's a seal that's failed and needs to be replaced. The water appears to be coming from the gap between the dial for the water flow and the dial for the temperature control at the front and it is dripping constantly and quite fast.
Anyone any idea what model this shower is please? And further to that what the problem is likely to be and where I might be able to find the parts to fix the issue? If anyone has any practical advice on disassembly of the shower too that would be great thanks.
I think I've figured out now that it's a Triton Dart. There seems to be a few different revisions, the Dart 1, Dart 2, and I think Dart 3 and Dart Eco are the same revision or at least share some parts. It's possible I would need to purchase all of the handle/knob assembly even if it is just the seal between the two knobs that has failed, unless someone knows otherwise? I would be nice to just replace the seal and hopefully that would fix the leak. This is what I came across on a couple different websites https://www.showerdoc.com/triton-handle-assembly-dart-3-86002900 and
https://www.bathroomspareparts.co.uk/triton-dart-eco-knob-assembly-from-aug09-86002900-67118-p.asp
That's expensive, it's probably just an O ring you need, take it apart and have a look first.
Thanks, I think that's what I'll do to have a look if there's anything obvious that's failed, hoping that it's just a seal and I can buy one that's suitable. In the manual for what I believe to be the correct model it shows 2 washers as part of the knob/handle assembly, these are rubber o-rings so I guess act as seals, and I would guess washer B has failed. One thing I'm not 100% on is do those act as seals or should water not be getting passed the cartridge to there anyway? I'm also considering the possibility that the cartridge needs replacing.
