How to renovate this external door?
8 Feb 2015
Hi all
Love the door; hate the colour.
Lighter colour is the original colour (first picture) which we much prefer. Darker colour (the other two pictures) seems to be stained.
Can I simply sand this back to the original lighter colour and then seal it?
Other option is painting, which I assume involves sanding priming and then painting with a suitable external colour?
Any advice much appreciated, as I've never done this before
If its a tined lacquer you could strip it with a chemical paint remover -get a professional one, but you wont get it as light as the inside, its likely to be patchy
Also you cant have a clear finish on the outside, clear finishes very limited UV protection, so you will need to use a tinted finish with a minimum colour of "light oak".
If you finish it clear, the UV will burn through the finish in about 6 months -I know I used to run a joinery company and have had this conversation with industry specialists numerous times.
If it was me I would use a sikkens type finish, maybe classic to start and then a top coat.
you will have to strip back if you want to change from a reddish tone to an oak tone
Super helpful thank you. I'm gonna have to Google all of this!
Thanks again for this. When you say "top coat", do you mean paint or stain? Not sure which is best here.
