Its purpose is to provide a currency that can be moved digitally without the need for banks, clearing, payment services etc.
and is there a problem to which that is the solution?
if it had been true that roman soldiers were given an allowance of salt on payday, it would more accurately be called a "ration" rather than a currency.Salt was and still is a currency. It’s where we get the term 'salary' from.
Yupand is there a problem to which that is the solution?
Yes and the same can happen with normal currencies but they are generally more stable and more likely to fall in value and have problems gaining when they have. It's not supply and demand with these it's more "desirability" but relative value is still set by trading.have you hear the term "a dead cat bounce?"
To divorce people from their local currency. It's as simple as that. Plus any other normal currency as well actually.what is the problem to which bitcoin is the solution?
If you thought about why some people in some country or the other might want to do that I wouldn't need to. If you can't - tough.can you reword that to show the problem you have in mind?
The problem of how to create money from thin air.what is the problem to which bitcoin is the solution?
but that can already be done.The problem of how to create money from thin air.
It doesn't solve a particular problem. It's a money manufacturing scheme that allows financial transactions to be undertaken without an individual country's oversight.but that can already be done.
what problem does bitcoin solve?
