Perhaps not a very good calculator.That calculator could not find a suitable PVC twin and earth cable for a load greater than 10kW
Why would it do that?Above 10kW it was suggesting SWA
Why not?As for diversity, It can be applied to most multi-element appliances in average use but unless the appliance has integral power management a rating based on diversity alone cannot be relied on.
Nearly every standard cooker and cooker circuit must fall into that category.
Because they are European and are just adding up the elements?If a 19kW cooker will in reality and due to diversity only be a maximum load of 7kW then why does the manufacturer describe it as a 19kW appliance.
Why? How much would it be without that?My dual ring induction hob does have integral power management which prevents both rings being set to full power at the same time.
