Hi All
I'm looking for advice on my hot water and heating issue.
I have an oil fired Potterton statesman boiler that works absolutely fine when the Honeywell st9100c programmer works.
However lately the programmer last about a day and turns off completely. At first, I could change the fuse in the spur and it would power up again for a day but now it won't at all.
I'm wondering if it is wired wrong or there's not enough voltage to the programmer to come on or even maybe the Honeywell cylinder stat
l641a1039 that may be faulty and stopping it.
Obviously, I'm not a skilled tradesman in this area and would like advice or a quote for someone to fix if it's someone you are able to repair.
I have attached some pictures of the wiring in the spur, programmer and 10 block for your reference.
Best Regards
Tj
Best Regards
Tj
