When we moved into the house the mains water pressure was so high it would splash out of the sinks when opening a tap fully and pop the hoselock fitting off my hose pipe so we got a plumber out and they fitted a Caleffi 553 pressure reducing valve.
This is all good, water pressure in the house is a bit more normal but we’ve since had a Gledhill unvented hot water cylinder installed to give us mains pressure hot water and so our mains pressure usage has increased (like when running a mixer tap with both hot and cold to fill a bath for example).
My question is how do I go about adjusting the pressure reducing valve to give us a bit more pressure?
The dial has a red needle which can be moved and is currently turned to 4 bar and that is approximately what the black needle is at when there are no taps running in the house. Got the dishwasher on at the moment when I took the pic.
There’s a screw adjustment on the end but not sure how much I should turn this and in which direction? does the + and - correspond to the effect of the valve in reducing the pressure of the pressure itself?
The tech sheets and instructions for the valve I’ve found online have confused me a little and so I want to make sure I’m doing the right thing before I touch it.
Thanks in advance
Rich
Thanks in advance
Rich
