I have a standard two storey house (less than ten years old) with dual zone (upstairs/downstairs) heating and a Baxi combi boiler.
I've come to put the boiler on and most of the radiators are not working - the motorised valves move and the boiler fires so I know there is hot water in the system but only one radiator actually is hot - one is slightly warm and the rest are stone cold. The pump sounds as if it is sending water around and radiator output from the boiler seems like there is hot water coming out, the boiler seems to suggest that it is regulating the temperature.
There are TRV's on each and I've tried hitting the pin with a hammer and nothing, still think that eight TRV's sticking is a little bit unusual. The front bedroom has a radiator without a TRV on it and that is cold (if anything I would think that would be the hot one).
Am a bit lost for ideas - does anyone have any suggestions - I was thinking possibly a blockage/restriction in a pipe? Try and drain the system and see how much water is in it?
