Why is this light dimmer buzzing?
There is a BG NBN82 dual dimmer switch pictured below. Each dimmer controls a separate lighting zone. Zone A has 8 and Zone B has 5 spotlights. All identical 500lm LED GU10 dimmable spotlights throughout.
The dimmer controls work equally fine for both circuits. But for Zone B only, a loud buzzing is emitted from the dimmer switch and the LED bulbs themselves immediately upon switching on. This happens regardless of the level of dimming; it is equally intrusive at both full and minimum light settings. Zone A is always silent.
The technical data (PDF) mentions seemingly nothing of relevance. While the product details (screenshot below) (PDF) states that: "There can be issues with dimming CFL and LED lamps at a low lighting level. The Nexus dimmer products have an adjustable minimum level feature which can be used to adjust the lighting output at a low level, to stabilise the load."
Adjusting either of the tiny rear flathead adjuster controls (pictured below) readily alter the sensitivity of the front dimmer switch on the light level of the circuit. But the buzzing noise remains equally loud from Zone B and the switch itself regardless of the level set or the combined configuration.
What could be causing this issue?
