I had a look at that a couple of years ago and thought about lining our living room wall with it - the wall is at a gable end and gets cold in winter; like a fridge. Not good. Trouble is, stripping back will be traumatic and redecorating that room expensive, so it's a job marked down 'to be done'.PIR is about 50% more thermally efficient than Rockwool. Rockwool has the obvious benefit of being largely fire proof. There is a lot of things in a building which are flammable, the key is to ensue they are encapsulated so they are less likely to catch fire and that they are not installed in systems where an air gap can cause a chimney effect in a fire. Unfortunately there is so much sensitivity around this, that not much effort has been put in to designing a safer PIR based system.
