- Joined
- 23 Oct 2022
- Messages
- 26
- Reaction score
- 3
- Country
I have a 30 yr+ Potterton Flamingo boiler with a hot water tank in an airing cupboard with a header tank and a header tank for the central heating. The boiler gets serviced every year.
With the cold weather the radiators are taking a while (30 mins or so) to start getting warm and then arent heating the house up to the point where the thermostat will turn off the system - its set to 18 degrees.
I did notice that the upstairs radiators were much hotter than the downstairs ones so balanced the system by only opening the non-trv valve a 1/4 of a turn (upstairs) which does seem to even them out. The boiler thermostat was set to 3/5 and ive put that up to the maximum now. Ive bled all the radiators. The heat is pretty even amongst them all but I have one towel rail upstairs that is now cold. The output from the boiler seems OK as the pipe is too hot to hold and I can measure about 55 deg C.
The hot water seems OK but I think im adjusting the thermostat in the shower more towards the hot side. The pump isn't noisy and the 3 way valve moves where it should.
Does anyone have any ideas of what to start with? I think it could be sludge in the system. If so is it feasible to flush without special equipment?
