Hi all,
I would appreciate any advice you can give. I have a gravity fed system with the following equipment:
Baxi Solo 15 HE Boiler
Potterton EP2000 Controller
Honeywell Sundial Y Plan Diverter Valve
Honeywell L641A1005 Cylinder Stat
Hot water cylinder in airing cupboard upstairs
Cold water tank in attic
We can only have the CH on when the HW is turned on, this isnt much on an issue, but this year, the CH doesnt always come on. The HW will heat up and some radiators will get warm, but not hot and 2 radiators barely get warm. As soon as the hot water is heated to temperature the boiler turns off.
I have tried switching the diverter valve to fully open and made sure it can be in the "middle" position but that doesnt always help (sometimes it does).
If i turn the cylinder stat all the way down i can get CH, but then this doesnt heat the water (or at least not much).
I have managed to get the CH on by fiddling with the diverter and turning the CH on and off a few times on the controller, but there isnt a constant thing that always works.
HW works fine on its own.
Does this sound like the diverter valve is at fault or is there another issue with the system?
If you need any further information please let me know.
