- Joined
- 10 Dec 2022
- Messages
- 15
- Reaction score
- 0
- Country
Hello fellow DIYers.
I have a system boiler with UFH, the UFH manifold is set in an S-plan with a hot water cylinder. The cylinder has its own thermostat to switch hot water on/off as needed, which fits on a pocket. The stat looks like this:
As you can see, the dial is set to 55C. And yet, water comes out at 66C at the tap. I took the stat out, put a meat thermometer in the pocket, and the meat thermometer measured 55C (even though it didn't reach all the way to the end of the pocket). Put the stat back in, turned the dial down, and it would only switch off the system at 35-40C.
Questions for my fellow DIYers:
1. My stat's broken right? Is there any other reason why it would behave like I described? The cylinder is in a cold loft so could the low external temperature affect the reading of the stat?
2. If it is indeed broken, what do I replace it with? Is there any particular brand/model you would recommend?
3. One frustrating issue with rotating dial thermostats is that you never know what temperature you're actually setting them to and what temperature they're measuring. Is there any good digital cylinder thermostat that shows the current temperature and allows me to select the temperature on a display? (The ESI ESCTDEB seems to be sold on quite a few plumbers' websites, but I have seen lots of negative reviews)
Thanks!
Thanks!
