I had my food dye ready to try to figure out what was going on with drains in my new house, lifted the manhole cover and found this...
There are pipes at each end that look a bit like clay underground drains, and are at right-angles to the road (where main drain probably goes).
I flushed a loo three times in a row and a little bit of water came in at the end nearest, but only a bit. This manhole is about 6ft from the house wall, although quite a bit further from the loo I flushed (at other side of house).
Is this just a very clogged up inspection chamber for a main drain? Or is it a soakaway of some kind? Should I dig it out?
I'm a bit stumped.
I'm a bit stumped.
