Hi folks, spent a while on these forums already but can't quite find something to suit my problem.
Main Combi Eco 30 boiler. (similar to many baxis)
Was working fine then started to have an issue with the hot water. basically when the boiler was called burner would cycle in and out rather than staying constant resulting in luke warm water at best. CH was working fine at that point.
Diverter valve seems fine as the problem happened whether or not CH flow valves were open.
I managed to solve the issue with a bodge where if i had the heating on max for a while so it was north of say 70 degrees I could use the hot water passing the HE to warm the HW as opposed to the heat from the burner. Not ideal but worked enough for a fast shower.
Now I can't even do that as the CH is now playing the same game, cycling on and off the burner while not getting north or 50 degrees (its set to 80).
I've checked the magnoclean filter and thats pretty clean, put a new thermistor on and generally spent a bunch of time trying stuff and reading up but with the CH now struggling to heat the radiators with the burner cycling in and out im thinking its new boiler time unless I can come up with a fix.
Any suggestions or advice greatly appreciated.
Thanks Ian
Thanks Ian
